U-Joint problem with 9 inch Picked up a 9 inch rearend. Got everything mounted and got the Napa 447 u-joint and put it on my stock driveshaft. My problem is the u-joint is not flush with the rearend. And the u bolts will not slide over the ends of the u-joint at all. Tried my stock u-joint and it all most works but still a little to big. Anyone |
It sounds like you have a 9 inch rear that does not have a 1350 yoke. You'll have to find out which yoke it is. Bob |
Originally Posted by BruteSpeed
(Post 13213471)
Originally Posted by som6969
(Post 13216214)
I found the problem. the rearend yoke is a 1310 u-joint. And precision makes and picked it up today and worked great. |
© 2024 MH Sub I, LLC dba Internet Brands
