10 bolt rear cover RTV?
Old 05-10-2010, 11:03 AM
99 Pewter TA's Avatar
Default 10 bolt rear cover RTV?
I just finished up doing gear oil change and my gasket is leaking. I want to redo it with RTV gasket maker. Will this do the trick? The cover is straight and old gasket material was removed.
Thanks
Old 05-10-2010, 11:31 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Yes, it should work. Just make sure the surfaces are fairly clean. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-10-2010, 01:08 PM
NoGo's Avatar
I used silicon gasket maker and it seems to work okay. I also silicone the drain plugs because they seem to leak as well. It makes disassembly a bitch, but it works.
Old 05-10-2010, 03:01 PM
Jawsgear's Avatar
Make sure the gasket surface on both the differential and the cover are completely clean and free from oil and old gasket or sealant material.
Jeff
Old 05-11-2010, 07:29 AM
Jeff
I used a razor to get the stuff off maybe I left some on the carrier thanks
Old 05-11-2010, 08:06 AM
01ssreda4's Avatar
Why not just spring for the gasket at the local auto parts store?
Old 05-11-2010, 08:38 AM
fleetmgr's Avatar
Important point about RTV....it only takes a little. You don't want to be in a situation where it spooges into the case when you put the cover back on.
Old 05-11-2010, 09:26 PM
1lejohn's Avatar
Get the stuff rated for gear oil. It is gray in color and isn't affectede by the oil as much as regular RTV.
Old 05-11-2010, 10:08 PM
SOMbitch's Avatar
I had the opposite problem....Mine leaked with sealant so I went to Mr Goodwrench and bought a $7 gasket, cleaned things up and good for the last 23K...
