Ring Gear spacer hey guys, got a question here, one of my friend swapped gears on his TA, and he needed a ring spacer. If I swap gears (410) is a ring gear spacer will be necessary? for an M6? Thank you! |
if you came with a series 2 rear ( a gear lower than 3.08(2.72)) you will need a spacer OR a 4.10 built for a series 2, if you came 3.23 and up you have a series 3 rear, you will not need a spacer Johnny |
That man is correct ^^^^ |
Thank you Johnny! I won't be meeting one then. |
© 2024 MH Sub I, LLC dba Internet Brands
