3.73's... I'm in rebuilding stage of my 99' A4 SS and I'm goin with a 383 stroker with a3600 or 4000 stall. I already own a set of 3.73's for the car but I wondering if it will be worth it to swap from 3.23's to 3.73's? |
I'd say that it will be, you'll get into the rpm range much sooner. Bob |
Originally Posted by Bob@BruteSpeed
(Post 13615981)
Originally Posted by LS1CALIBOY
(Post 13616098)
Do you think I should keep the stall a 4k? I don't want to run out of gear... |
if you still have the stock 10 bolt ,upgrade to a 9" or 12 bolt.a 383 will brake the 10 bolt. |
If you drag it, 4K. If not, 3600 |
Thanx for the imput fellas I'll prolly go with the 3600 seeing as I will see more street than drag time...Also I plan to get a rear end once the Motor/trans are in and I start focusing on suspension. Prolly be my next deployment purchase. But for now I think I'll just rock the 10 bolt with the gears... |
| All times are GMT -5. The time now is 09:19 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
