newbie question on rotating the rearend
I have a Midwest Chassis 9" rearend in my fourth gen. I got the gears swapped in the third member and got the third member on the housing. I got the driveshaft on, but when I went to put the adjustable (heim joints) torque arm on, it looks like the rearend needs to be angled downward in order for the ta to go on. The pinion on the rearend is pointing to the floorboard pretty high anyway.
I've never done this before so what should I disconnect on the car at the back to help the rearend point more downward?
Thanks for any help/advice.
So I'm sure if I can get the rearend to angle downward I can get it in there. I know the torque arm is what prevents the rearend from rotating up or down, but I was wondering if there was anything else that prevents it from rotating also.
It's not on a lift; it's on jackstands.
LS1Tech Premium Sponsor
If you are trying to do this with the rear end hanging it will be more difficult. Support the rear end up under the vehicle and things should be easier to put into place.
You are more than welcome to call me so I can help you our send me some pics at midwestchassis@hotmail.com
Finally got it sorted out. I'll post this in case any other newbs have trouble. I used a second jack (the yellow one in the pic) to lift that part of the rearend, and it tilted forward enough for me to get the top torque arm heim joint on.
I also moved the jackstands from the rearend to the subframe. Made it much easier to move the rearend around. Definitely a duhhhh moment.
Jason, thanks a ton for putting up with all my newb q's about the gear swap. You guys have the best customer service! I got two heat cycles done today; will finish it up this week. Can't wait to take it on the highway!!
