Rear diff cover bolts torque specs
Old 09-13-2010, 06:42 PM
~Firehawk~'s Avatar
Default Rear diff cover bolts torque specs
Can someone tell me what the torque specs are for a stock 10 bolt rear diff cover for a 02 Trans Am (m6 if t makes a difference)
thanks
Old 09-13-2010, 07:39 PM
bigj2717's Avatar
22 ft-lbs
Old 09-13-2010, 07:41 PM
Snake_Skinner's Avatar
Are you using a gasket or RTV?
Old 09-13-2010, 07:48 PM
~Firehawk~'s Avatar
gasket
Old 09-15-2010, 08:14 AM
~Firehawk~'s Avatar
Originally Posted by bigj2717
22 ft-lbs
thanks bigj2717. Is 22 ft-lbs for both rtv and gasket?
Old 09-16-2010, 08:56 PM
Greekey's Avatar
Yes...
Old 12-30-2014, 01:35 PM
lbramel's Avatar
22 ft lbs is WAY TOO MUCH...... you will crush the gasket and warp your cover. I use 120 inch lbs with gasket and RTV no leaks. DO NOT USE 22 FT LBS.
Old 03-10-2019, 05:33 PM
lbramel's Avatar
Default Differential Cover Torque Specs.....
As per my previous reply DO NOT USE 22FT/LBS or more to torque on the cover if you use a purchased gasket such as felpro....YOU WILL CRUSH THE GASKET AND WARP YOUR COVER RUINING IT!!!!! I used the gasket and a little bit of permatex black and torqued to between 100 to 120 inch lbs last time and this time....no leaks and no crushed gasket..... i put way too many miles on for this change but you can see how many years its been with no leaks at all....hope this helps someone out........
Old 03-10-2019, 05:42 PM
lbramel's Avatar
Default Changing Differential Oil.......
On a side note.... make sure you get the oil that runs out into the bottom bolt holes out by putting in the bolts and pushing the oil out and then some twisted paper towel pieces to soak up the rest BEFORE you try to mate the new gasket and bolt it up with the cover. If you don't get that oil out it will come out as you put the bolt in and push through your gasket you just made as you tighten it down and possibly leak..... i discovered this trick long ago by trial and error LOL....
Old 03-12-2019, 02:35 PM
bleepster's Avatar
even this is a resurrected thread - here we go:
taken right from the factory service manual:
Old 03-12-2019, 02:39 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,459 Likes on 1,052 Posts
22 lb-ft is correct per the Helms (GM) manual.
Quick Reply: Rear diff cover bolts torque specs
