Rear end weights, didn't we have a list?
I can't seem to find the weights of the 10 bolt, 12 bolt, 9", S60, I thought we had a thread but did a search and can't find it.
Can someone help me out? Thank You
it was a this vs that vs them thread a little while back. if you scroll through the past few pages in this section you will see it.
this one maybe?
https://ls1tech.com/forums/gears-axl...m9-weight.html
this one maybe?
LS1Tech Sponsor
this one maybe?
this one maybe?
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
youll have to put MWC in the mix too. Something that could skew the weights on the 9" are the center section materials i know my aluminum one is a bit less than the iron one. Im sure axle splines could make a dif, but ive never handled anythign other than stock and 35 spline axles
LS1Tech Premium Sponsor
We could be weighing housings for days if we were to weigh all the different combination's we can put together.. I know we can get our housing lighter than a 10 bolt with all the available options we have. You will need to separate standard nine inch housing to something like our fabricated housing because there will be a difference there as well.
LS1Tech Sponsor
You won't notice any 1/4 mile time difference with a heavier rear-end. I've had guys put the standard non fabricated (not the lightweight Moser fabricated M9) Moser 9 inch in their cars with the same gear ratio they had in their 10 bolt, and they said there cars were now faster in the 1/4. It probably has to do with them not being afraid to be aggressive coming out of the hole like they had to be with the 10 bolt. Bob
__________________
With what Eric said i thik its more importat to get the POPULAR combiatio weights. Yes they ca pry make us a rear that weighs a **** ton less tha a 10 bolt, but how much of us ever get somethig more tha the 9" that is basically stock width with either a wavetrac, true trac or spool?
When you are talking weights, the 12 bolt is around 30 pounds lighter than a standard 9" housing. An the standard nine inch is around 50 pounds heavier than the stock 10 bolt. Something like our fabricated housing we can get lighter than a stock ten bolt.
It is hard to pin point a common package to go off of, With their being so many combination's I can't think of were to begin.
