Low Trac Light from 60-65mph after rear end swap... - Page 7 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
Reload this Page >
Notices
Old 08-03-2018, 07:18 PM
  #121
i was never told that my 4 channel may or may not work, nor was i told tweaking would be involved.....i was told along the lines of "we have sold hundreds of these rears, and nobody has ever said there 4 channel has never worked. but most of these guys dont do any 3 or 4 channel mods because they are race cars".
again, what do i need to shave in order to move the sensor closer to the reluctor. trust me, i have read many things about what can cause this system not to work.....well aware of all the stuff u mentioned...its not any of those. i had gm use the tech 2 to monitor stuff. the only thing i have not done is check the distance because i just recently read that in this thread. hopefully i will accomplish this weekend
Floorman279 is offline
Old 08-03-2018, 07:22 PM
  #122
Originally Posted by 01ssreda4 View Post
Its definitely a finicky system IMO. Of course OEM stuff was never designed to be cutting edge, only just good enough to get through the warranty period.
funny you say that.....just happened to be doing a brake job on my 2002 taurus. just has abs. the one rear reluctor was super crooked, the magnet was literally caked with god knows what, reluctor a little rusty and i had to tap the ring a little less than 1/8" to straighten out....no abs issues before or after i straightened it. literally thought, "my friggin camaro has this that, new abs parts and still can't work.
Old 08-10-2018, 02:38 PM
  #123
Originally Posted by MidwestChassis2 View Post
Now for the housing being crooked. The housing could be a U and it would still not effect how the 4ch reads, it just needs the ring to spin and a sensor to read it. Not that this could happen for obvious reasons but you could mount the housing end ontop of the axle tube and it still just needs to read the reluctor wheel from the backing plate. As long as the backing plate is mounted to the housing end it should work. A wobbly ring can effect how it reads and this is where we get back to making sure it is 100% true when spinning. Another issue is you need to shave the sensor with aftermarket housing ends to fit and this step is often not done or not done well enough. This is do to the bigger housing ends to fit a bigger bearing. If you force it in the pick up portion will be at an angle and you need to make sure it is parallel with the ring.
I think the statement in bold is most likely my problem. I will check the air gap but it looks very close to the 10bolt gap. There must be something to the signal around the 60-80 MPH mark as that seems to be where the majority of the problems are. Maybe at that speed is when the signal tolerances get tighter or something so a tone ring wobbling before that is still within spec. Its just odd that mine doesn't do it all the time. Maybe 50% of the time around those speeds is when I get an error popping up. Mine also seems to be much more sensitive to bumps in the road causing an error as well.
Chrisingermany is offline
Old 08-11-2018, 01:53 PM
  #124
still waiting for mwc to tell me what needs to be adjusted for this to work.......
Old 08-13-2018, 09:33 AM
  #125
LS1Tech Premium Sponsor
MidwestChassis2's Avatar
Like stating previously check all these scenarios-
Different size tires, low tire pressure, spool, non spooled differential locking up like a spool, powder coated backing plates, ground down backing plates during cleaning, bad sensors, deteriorating wiring, pulling wiring out of the plug during disassembly, not pushing the plug in completely on reassembly, bent backing plates, not using the tin shield, and so many other things to consider that may cause unforeseen issues. The final step is to make sure the wheel spins true and adjust the gap on the sensor until the system reads properly.
I hope that helps.
__________________
Midwest Chassis, Inc. 309-382-6252
www.midwestchassis.com
EMAIL- [email protected]
Online Purchasing~ Online Purchasing, Install Pictures, Helps & How To's, And Customers Rides
Follow us on Ebay~ midwest_chassis
MidwestChassis2 is offline
Old 08-13-2018, 03:59 PM
  #126
And as I have previously said, I done all that stuff. What does MWC recommend I do to adjust the gapp of the sensor to the reluctor wheel since that is non adjustable without modifying something
Old 08-13-2018, 04:55 PM
  #127
Modify whatever is needed to be modify to tighten or expand the gap as needed until the ABS functions properly if that is indeed the issue as there is only the backing plate or the sensor itself to choose from.
__________________
Old 08-14-2018, 07:09 AM
  #128
I used a dial gauge to make sure the ring was running true. I filed the sensor housing itself to allow it to move and point once bolted down. Thats how I did it on my Fab 9. . .when ABS didnt work I looked at individual wheelspeed sensors using a $5 USB interface and the Torque app only to find I had a bad front sensor, the rears were working. It had gone bad sitting on stands for a couple of years. YYMV, GL.
edit: I also made sure the sensor pickup shaft ended up parallel to the notches in the ring and perpendicular to the reluctor's plane of rotation. I used a little bit of ultrablack over the sensor housing, paying special attention to areas that were filed...the sensor failing on the stands makes me think the issue with the stupid things is moisture ingress.
therabidweasel is offline
Old 08-14-2018, 02:25 PM
  #129
OK will look into that way
Old 08-14-2018, 08:36 PM
  #130
Originally Posted by MidwestChassis View Post
I'm sorry I wish I would of seen this before I left the shop. I would of got you all the proper measurements you needed. I might be swinging in their tomorrow because we have a ton of stuff going on I will look it up and get back to you, other wise i will call Eric and have him get the measurements you need.
Thats customer service right there...right on Midwest .
qweedqwag is offline
Quick Reply: Low Trac Light from 60-65mph after rear end swap...
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
