Narrowed rear end pics please!
#41
LS1Tech Premium Sponsor
The only way you can go narrower than -3.5 per side is by narrowing the LCA brackets plus running race brakes, we can then get you -5 to -5.5 per side depending on housing ends. Keep in mind when narrowing your rear end to chose your wheels first because some manufactures do 4"BS, 5"BS, and so on were others will go 4.5"BS, or 5.5"BS. Then there are manufactures that will do what ever you want.
#48
explorer brakes work great , fit inside a 15 inch drag wheel, can use 9 inch housing ends welded to the 8.8 tubes like i did and they bolt right on. e brake was also very easy to make work. and i swear it stops better now. the ford stuff is beefy.
