Guys with Dana S60's I have a few questions.
LS1Tech Premium Sponsor
I will touch on a couple items I noticed while glancing the thread, if you want something specific answered just ask.
Rear cover- It is a new version stamped unit last year, have not heard much about it leaking. As for the aluminum cover Strange will not use it as an upgrade sold "with" the rear end but you can purchase it separately and instal it yourself. There was fitment issues with it.
S-60 S-Trac or Truetrac- The S-trac in the S-60 is not like the S-trac they offer in a 9". It is very similar to a Truetrac in many different ways down to it's limits. I just don't want to see people confused in thinking they are getting some 700+ hp differential.
Now do not get me wrong it is a great differential and performs and takes a crazy amount of abuse. It will just be limited to what it can do like the Truetrac is.
What kind of power are people putting to them before there are issues?
A vehicle making 1000hp could never break a Truetrac, S-trac, or a clutch style posi not only in the S-60 but this goes for any rear end if they are not using it for drag racing but you could have a car making 500whp break one if they do nothing but beat on it in a drag racing application by weighing in over 3400 pounds on a sticky tire with 6000rpm launches.
Certain things will always be true when it comes to building a rear end, if you plan on drag racing no matter the HP level your best option is to use a spool in a 12-bolt or S-60 because it will be the only bullet proof differential that should never break on you. The S-trac or Truetrac in the S60 will be OK but is no guarantee it will take everything you throw at it over time. Most likely most will never see an issue with either one in the S60 but it is a possibility.
If you want a rear end that can be the best of both worlds your best option is a nine inch preferable one of our fabricated nine inches based off all the different cases alone we can set someone up with but that is a hole other conversation. With the nine inch if you want bullet proof for drag racing and some street cruising you use a spool, it how ever is not the best of both worlds differential BUT a nine inch has the option of the S-Trac which is a beefed up version unlike the version for the S60 or the other option which is the Wavetrac. These two differential options alone minus initial cost will do what ever you want it to do and take all the abuse you can toss at it, plus if you find their limits Strange or Moser are here to offer up their limited lifetime warranty. We have not had to put that warranty into effect as of yet with the S-Trac but two customers have had to use it with the Wavetrac and Wavetrac has since changed their design and the two that had issues they took care of with out any hassle.
I hope this helps some and if you have any more questions please just let me know.
That is a loaded question that is extremely hard to answer. Out of all the S60's and we sell a ton of them through the year not only because of price but the fact we offer a discount on suspension items with the sale plus tech help but to answer your question we have not seen to many issues at all.
Not really because they are the same as far as function and form in a S60. One is just manufactured through Strange and the other is through another manufacture. The Strac in the S60 does not get the life time Warranty like it does for their nine inch version.
Not in the S-60 form there is not according to Strange. Keep in mind the S-60 doesn't seem to have the same issues using a Truetrac like a stamped nine inch housing does. Even our Fabricated nine inch housing has very little issue using a Truetrac, all though we suggest our Billet Clutch Posi over it. We have guys in all different HP ranges with it.
#33
#34
The above is NOT true for the 9" Ford.
Al 95 Z28 S60 w/spool
#35
https://ls1tech.com/forums/gears-axl...o-numbers.html
info when I 1st got my s60
Hears how my truetrac was at the track
https://ls1tech.com/forums/drag-raci...-truecrap.html
#36
I think I got some unhardened axles at 1st I twisted both of them. The car was stock interals with some mild bolt on making 330whp. Strange sent me a whole new axle setup for free ASAP, then a put the twisted ones in thous boxes and they had them picked up. Been fine ever since, and they stand behind there stuff. Same with some of the drag brake kits some parts had to be changed that didn't work in a new kit style.
https://ls1tech.com/forums/drag-raci...-rear-end.html
#37
Sorry to kinda jack the thread but I am putting a Dana 60 in my 01 ext cab I was wondering if some one.knew the wheel mounting surface of a 2001 ext Silverado? So I can change it to a six bolt? Or direct me to the right area :/
