New 9" and weld on Lca's The 9" came in and i have a question. can i get my LCA relocation brakets welded on before the install of the actual rear end or does it need to be in the car? If i can get them welded on before i install the rear, Ill have it done before i put the rear together, that way Im only lugging aroung the housing. TIA S |
I like to weld the brackets once the rear is in the car, that way you can just if they are on in the right position. I bought a used 9" and the person before me welded the brackets too far back, so I have to adjust my LCA almost all the way out to make the rear sit where it needs to |
| All times are GMT -5. The time now is 11:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
