S10 gear help
Old 07-07-2012, 11:11 PM
cbr600rx7's Avatar
Default S10 gear help
My friend has been saying his 94 5 speed S10 4 banger has no power.... And of course he seems to be lost to why this is . Any way i checked his RPO codes and the truck list his rear diff code as a GT4 (3.73) rear gear, However today i had the truck in the air doing is brakes i marked both the drive shaft and tire and rotated the drive shaft about 2 1/4 times to one full tire rotation . This made no sense to me so i checked it two more times and each time i spun the drive shaft about 2 1/4 times to one full tire roation. This would mean the axle ratio would be somthing like a 2.23
What the hell is going on here guys because i am lost.
Old 07-09-2012, 09:47 AM
Ethan[ws6]'s Avatar
Has he put bigger tires on it? A taller tire will effectively make the gear ratio numerically lower.
Old 07-10-2012, 09:39 PM
cbr600rx7's Avatar
NO. He is running stock tires. And this is a rotation test so the tire should still turn one time per x amount of given gear.
Old 07-16-2012, 01:11 PM
Big Al's Avatar
It's the differential. You need to turn BOTH tires or it's 1/2 the ratio. So, half of 3.73 is 1.865.
Al 95 Z28
