LPW Ultimate cover question
Does anyone run an LPW Ultimate cover on their 10-bolt? If so, were there any clearance issues with this cover?
I did search this, but didn't come up with anything.
Thanks in advance...
Actually, I run a 24mm rear bar and the LPW Ultimate cover and brace kit and it doesn't hit at all...
You will have no issues using the LPW Ultimate cover, just be sure to order the correct one...
The above guy must either have the wrong endlinks on the sway bar... With the right length end-links it does not hit... End-links are proper length when the body-mount and the sway bar itself are parallel to each other. Any angle between the two and you need different end-links.
It looks as if it going to be very close with little clearance for the panhard bar and the LPW Ultimate minimum clearance cover and brace kit.
I can't measure it because the rearend is out of the car. I don't want to weld in the brace kit brackets only to find out I won't have enough clearance for the panhard bar.
Anybody have this setup? If so is there clearance for the bar?
