Nine Inch Install - Brake Mounting Module(?) When I removed the stock 10-bolt there was some kind of module that had the brake lines connected to it and was mounted on the pumpking. What in the heck do I do with that now with the 9". Is this the thing people are just using zip-ties on or do you have to make a bracket or something? |
I made a small bracket (see pic) out of aluminum strip that you buy at ACE hardware, its like 3/4 x .100 or something like that - works fine and better then zip ties.. |
kp makes things look so clean! |
Originally Posted by CANNIBAL kp makes things look so clean! get it :chug: |
I'm lazy...I just took some wire ties and tied it. Still holding so far. :) |
Originally Posted by kp old 'bracket' racer get it :chug: |
© 2024 MH Sub I, LLC dba Internet Brands
