Dana 60 rear end I have a Dana 60 12 bolt in my 02 SS. I have a concern though, between shifts it makes a noise (clunking). Doesn't do it during driving, but overall it just seems quite loud compared to my old 10 bolt. Is this common? If not, what can I do to fix this? |
you sure its the rearend and not some type of susp. part making the noise?? |
I'm honestly not sure.... I figured that it was just the rear end, wanted to see if anyone else had similar experiences. |
Well I think I found the source, I have quite a few solid mounts, I think polyurethane. So it's just a noisy ride. |
i have poly mounts and i dont get any noise now if you had rod ends that would be diff story bc they make noise |
The noise I'm trying to describe may be confused for something else. I'm double checking everything under the car and haven't come across a problem...yet. |
It is either a S60 or a 12 bolt not both. The poly bushings should have no effect on shifting. What type diff? Are you A4 or M6? |
It's a dana s60, its an m6. I'm still waiting on the seller to mail reciepts and parts lists of the car to figure out exactly whats done to the car. |
© 2024 MH Sub I, LLC dba Internet Brands
