Posi Vs. Spool So ow bad is a spool on turns?? Ive heard that they arent suitable for turns and stuff?? How do they compare to lockers and posis??\ Thanks:cheers: |
my locker is interesting in the parking garage up 5 floors..... it is a bit much for everyday but in most cases it isn't that bad... I have no idea about a spool though. |
Spools kick ass! you can hardly tell its there just makes turning a little harder especialy without power steering |
Originally Posted by SUX2BU Spools kick ass! you can hardly tell its there just makes turning a little harder especialy without power steering |
My car has 100k miles and i drive it every single day. no power steering and its the stock rack n pinoin. i have front runners on it so its not that bad. i like it less drag on the motor with the short belt and a few lbs off the front end. its kinda hard at first but then your arms get bigger and you get used to it. and then when you put the spool in its like you start all over again, you gotta get used to it again cause it gets even harder to turn. but i'm sure i'll be one handing it in about a week. |
© 2024 MH Sub I, LLC dba Internet Brands
