The more I research gears the more confused I get....
I have a 2001 Firebird Formula A4 with the stock 2.73 gears.
I am looking to upgrade my gears into something higher, and from what I've come up with 3.42's are my best bet since they are cheap and oem from m6 ls1's.
Now this is where Im confused. I keep reading that 3.42 gears will not fit into my a4. What else do I need? Do I actually need anything?
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
Just make sure you match up 3 or 4 channel rear , if your car has traction control it's 4 channel , no traction control 3 channel
Just buy a ring gear spacer and stock 3.42s will bolt up. However, I personally wouldnt run a used gearset, go new instead. Motive GM75373x is what you want. You'll thank me later.
Thanks for everyones replies. I almost made a mistake and bought gears off craigslist. Right before I was going to pick up the whole rear end I read my door sticker and it turns out my car has the 3.23 performance gears from the factory....
Looks like gears is pushed back on my list of mods.
I went from 3.23's to 3.73's when my pinion bearing gave out. Was a good difference in getting out of the hole. I had a local shop do mine for 700 i believe. They used Yukon gears. Still holding up well for me, but i have heard some people say stay away from them.
