Opinion on gears with nitrous
Ok so I'm a h/c/I car that's making 450rwhp and 400 ft lbs . My question is what's everyone's thoughts on 4.10 or 3.90s on a m6 I'm planning on a n2o set up next yr. would any of you go with the 3.90 to help stretch each gear out or am I thinking of this wrong? I just don't want to spray and blow through the gear so quick. I know nitrous likes to be lugged a little.
You would barely notice the difference between the 2. You notice a difference between 3.73 and 4.10.
Throw in whatever is cheapest if that is the ratio you want. Personally, I would go with a 3.55 or 3.73 as stated above.
Seems to me that a 370 range gear set is the best for nitrous. You need to figure out what size tire you will be running to ensure you can make it through the 1/4 within your rpm band while still in 4th. I run 375s and have been very happy with them.
No way you'll be able to spray any kind of a shot on 26s with 410s or 390s. I figure trap speed will be somewhere around mid 130. I would step up to a 28" tire for the track and run 3.90s. If your spraying out of the hole the more tire the better. That'll give you a decent gear in street mode to but leave you enough room to trap high.
