Gear pattern, could use a little assistance
Be gentle as this is my first ever attempt at a rear end, but I wanted to try to teach myself and learn. I ended up with this pattern and I am a tad confused as to which direction I needed to go. If you guys could steer me in the right direction, that would be great. All pics are as it sits. We would just repaint and roll it around again. This is on a Ford 8.8 with around .008 backlash and .002 runout.
Have you tried putting tension on the ring gear while rotating the pinion gear? I would repaint the gears and try this. This will give you a better/ cleaner pattern.Overall the pattern looks good. Post results if you can and I will take another look.
Otherwise, I agree with others who have indicated the pinion is a bit too deep. Add about .003 to the pinion carrier shim stack and recheck.
