Noise from new Moser 9inch
Ok, I just installed a Moser 9inch with a trutrac and 31 spline axles. The car seems to run fine is a straight line but as soon as I turn, even slightly, I get a horrible grinding/binding from the rear end. I havent had a lot of off time to try to figure out the issue, and I am scared to drive it as is. Another question is about my LCA's. There is a small amount of room between them and the brackets that hold them even though the bolts are tight.
There should not be any space between the brackets and the LCA's.
When I got my Moser 9 inch the gears weren't setup correctly. I took the carrier to someone I trust to check them out.
After I installed the axels it was very hard to turn them. I thought they were to tight so I took everything apart to check it. Turning the pinion by hand was difficult.
Take everything apart and double check that everything is installed correctly. Double check the torque specs.
I suggest you contact Moser and ask them about the noise you hear.
As far as the space between the bracket and the LCA's you might be able to shim them with washers, use grade 8 if you do.
LS1Tech Sponsor
I was swamped today, sorry about that. Look to see if the torque arm or the torque arm mounting bracket is rubbing the sheetmetal of the floor. There are two places where it can make contact. This seems to make more noise when turning. If it is rubbing, all you have to do is to shove a prybar up between the torque arm and the floor and pry the floor in a little. Let me know what you find out. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I got home and jacked the car up to take a look for anything rubbing and to check the clearance of the TA and mount. I didnt see anything that should pose a problem but I went ahead and pryed the tightest spots. Went for a test drive and I did even make it out of my neighborhood before hearing a loud pop followed by the sound of what I think is something broken and slinging around in the chunk. I have no idea where to go from here. I was able to limp the car the short distance back the house. But something is definitely screwed up badly. I dont see how it could be a install issue on my part?
LS1Tech Sponsor
__________________
Other than the axels or the axel bearings the only thing in the rear is the carrier. I doubt you broke an axel. Axel bearing is possible but not probable. So that leaves the carrier.
Follow Bob's advice since he can help you out with Moser but I bet it's the carrier.
LS1Tech Sponsor
I have an authorization number for you to send back the center section. I'll pm you. Thanks, and I'm sorry you are having a problem with it. Bob
__________________
Yes, I am sorry it has taken me so long to get back to this. I pulled the center out and I didnt see anything that looked out of place (no metal shavings, marred up gears, ect) so I took it to a friend at a local shop. He went through it and said everything was good to go and then asked me if I had ran friction modifier through it. I immediately felt like the biggest moron in the world. Soaked the clutch disk in friction modifier for a while and put everything back together and it is great. I cant believe I overlooked such an easy answer. The rear is running great now and I am loving the new 4.11's. Thank yall for your help!
