Extreme Chassis 8.8
LSX Mechanic
Originally Posted by PG45
anyone have this rear in a lowered car?
I would recommend an adjustible panhard rod to anyone running the 8.8. It will need some centering when you get it on, which can't be done with a solid non-adj panhard
No, they use their own housing so, you keep your own stuff. The only things are the backing plates which he is putting on for me for 80 bucks which I would get back if I sent him my cores. I think the rear is the best choice. It's lighter then both the 12 bolt and the 9in. And it's only 15 pounds or so heavier then the stock 10 bolt (read theat earlier somewhere don't know if completly acurate). I also would go on a limb and say that it's stronger then the 12 bolt. Mine is coming with 31 spline axles, Eaton HD posi, 4:10s, 1330 yoke, conversion u-joint, set up for 4 channel ABS, bolt in axles, T/A girlde, Stud Kit, and weld on lower control arm relocation brackets (100 extra) and cotst me was 2155. And there is absolutly nothing to fab. It bolts right in, using all the stock suspension components, and I guess now even the stock length drive shaft. By the way it's only 1880 for the basic setup without the girdle and stud kit and even less if you don't want bolt in axles. You really cant beat the price.
Originally Posted by Hardtop00SS
Is that price include shipping?
btw, i have freight discounts with several freight carriers.
nobody could touch that...
The 8.8 was my first choice. Craig's one cool dude, but I needed one right away and I knew he was backed up badly. Has that improved?
Also with all the bells and whistles, the price between the 8.8 and a 12 bolt is minimal.
I paid $2224.oo for my Strange 12 bolt.
where did you pay $2224 for a fully loaded 12 bolt? is that including shipping?
The rear is top quality in every aspect. It's fit and finish is perfect. I like the fact that they dyno test the unit before selling it. They even thought of stupid little things like putting grease fittings at the axles.
P.S. The shipping was added to the $2224.00 from my recollection. (Around $125 to FL.)
