What Type of Posi Is This? I bought a Moser 12 bolt used a while back and have decided to install 4.10 gears to replace the 3.73. I pulled the differential out to check the clutches and thought I had an Eaton unit. Anyhow, it looks considerably different than all of the Eaton info I've found. There is only one set of clutch packs and it looks like someone took a grinder to the ears. https://cimg8.ibsrv.net/gimg/ls1tech...e1095eb4a9.jpg https://cimg9.ibsrv.net/gimg/ls1tech...7efe89ab78.jpg Looking for any info on this so I can set it up properly. Thanks, Jim |
Some additional info: the differential mates up to 33 spline axles with the c-clips eliminated. There's a casting number - GV88-34H. |
Eaton Posi is the ONLY one made (to fit the various U.S. domestic solid rear axles), which use those carbon clutch packs. |
© 2024 MH Sub I, LLC dba Internet Brands
