Vibration after rear end rebuild..
I have a slight vibration after a rear end rebuild; the stock eaton has been replaces.
Now the car as a slight vibration above 75-80mph under load. When I let out, it stops. Its not that bad but its there and annoying. It does not get that worst at higher speed, just slightly.
I looked for loose DS bolts, and its not that.
De alership did the repair.
Is it the pinion angle? Car is a 2013 Camaro SS and it never had a vibration before the rebuild. Car has less than 20k miles
