advantages of changing gears after putting in a trex cam?
Not sure if this is the right board to post this but oh well. I am putting in a t-rex cam soon and everyone is telling me i should "change my gears". What do they mean exactly? What are the advantages from changing them to 4.10? Sorry for just a newbie question.
Originally Posted by jrp
you want gears so you can stay in the "narrow" powerband.
SN95 Director
Originally Posted by freakynipples69
But changing my gears will affect my car how exactly? does this apply to A4's only or also to M6's?
LS1TECH Sponsor
so after getting my cam i should change to 4.10 gears. how much do they usually go for?
Here is a good link describing the effects of gears and tire ratios.
http://www.thirdgen.org/newdesign/tech/gears.shtml
This link is a How-To if you are wondering what all it involves.
http://www.geocities.com/MotorCity/Downs/4013/re.html
Too answer your question....the car will simply fall on its face when you let the clutch out under normal driving manners. It feels like it is bogging all the time until you get under way. I have h/c and have the same problem. With 410 gears it will quickly get the revs going and avoid that problem. Second problem is addressed above. You will have a lot of hp and because the 410 gears are thinner you may have problems. You now are in the same boat as me.....need 12bolt and gears to complete the job and it will drive a ton better.
exactly what is a 12bolt and how much do they go for?
well i'll leave my cars gears and rearend as it is and get a really good tune from east side for now. From what i have read on this board, people seem to be doing fine like this. Tell me if i am wrong?
With that cam you'll want some taller gears like the 4.10's. The Trex makes it best power high in the power band and the gears will insure that you stay up there.
I dont have 2k for a 12bolt. Is getting 3.73 or even 4.10 gears really that bad without getting the 12bolt too? Exactly what can happend? sorry for all the questions but i am new to all of this and i am trying to learn.
You need a plan for moding your car. A cam is a big choice and a big cam is a bad choice without a plan. I'd say sell the Trex and get a 224 or a 230 max with stock heads and stock gears.
Maybe you are right. I'll do a little more research and see. Thanks again guys as always.
