12 bolt identified
Its a Moser most likely. The reason you can tell is the fabricated spring perch. Strange purchased the molds for the original brackets and reproduces them so they are identical to a stock 10 bolt, where Moser makes theirs from scratch.
I was under the impression Strange use two long bolts to bolt the torque arm on, where as Moser used 4 shorter bolts. I know my Strange housing uses the two longer through bolts. Hope that helps.
