Where to get proper gear lube for Detroit TrueTrac?
Old 02-26-2017, 09:44 AM
Billiumss's Avatar
Question Where to get proper gear lube for Detroit TrueTrac?
Hi Guys,
I'm going to be replacing my gear set in my 9". (going from 3.89 to 3.50 for turbo kit)
I want to get the proper gear lube, either 75W90 or 80W90 without any limited slip additive since the TrueTrac recommends plain jane gear oil. I've looked all around locally and can't seem to find any without it.
I've put Lucas and Valvoline in before, but at the time I didn't realize they had the limited slip additive in it.
What are you guys using for your TrueTrac and where do I find a good quality gear lube without the limited slip additive?
Thanks....
Old 02-26-2017, 10:03 AM
Carl at CRP's Avatar
Strange includes Lucas oil with each complete rear end sold, this is the oil they send. This is also what You get when You order a TruTrac.
http://lucasoil.com/products/gear-oi...0w-90-gear-oil
http://lucasoil.com/pdf/TDS_Lucas-SAE-80W-90.pdf
http://lucasoil.com/find-a-retailer
Carl
Old 02-26-2017, 10:21 AM
01ssreda4's Avatar
Can get it at walmart or generally any auto parts store
Old 02-26-2017, 10:36 AM
Billiumss's Avatar
Seen that at AutoZone, Walmart, etc
Quick Reply: Where to get proper gear lube for Detroit TrueTrac?
