Zr2 rear axle swap. Anybody else?
I swapped in the 8.6 ZR2 rear axle from a 1999 S10 Blazer into my 3Rd gen Camaro. Axle was 1.5 inches wider total WMS TO WMS. It's about 3 inches narrower than a 4th gen. It only has leaf spring brackets ro remove an only comes with disc brakes and 3.73 gear ratio and GM gov loc posi and 30 spline axles. Swap out the posi for a locker or true track and you have a very stout rear axle assembly. I am pretty sure you can get a 33 spline axle and spool upgrade for diehard drag racers.
the ZR2 axle is much stronger than the camaro axle. It is the same as used in GM 1/2 ton trucks. ZR2 axles all came with 30 spline axles, a 3.73 gear and the gov lock posi.
https://www.thirdgen.org/forums/fabr...oad-racer.html
A LOOOOOOOT of fab work onthis car. Not a quick and easy bolt in, lol. But nice work.
Shou;d have kept the 6 inch cowl! hard to see around but badass on a racecar.
Hope your health is is good.
