10-bolt Pinion Bearing tool
Ok so I was wondering if anyone has seen the pinion bearing machined to slide on and off for test fitting for a 2000 T/A?
I found threads where people talk about them and i have used them on other rear ends buut of course I cant find one for this car?
I appreciate your input
Buy an extra pinion bearing and make one with these. Simple.
http://www.ebay.com/itm/1-4-Air-Die-...1%26rkt%3D1%26
http://www.ebay.com/itm/SF4D-Tree-Sh...QAAOSw7GRZBezG
I have both pinion bearings done for 10 bolt, 12 bolt/8.8 ford. Spend the extra and get the new bearings ahead of time, and just file some away until they slip fit with no slack, even by hand its pretty easy to do. If you dont have access to air you can buy one of these.
http://www.ebay.com/itm/HEAVY-DUTY-L...IAAOSwal5YLkf2
