Pinion angle? Massive vibration 45mph
FIXED! SEE POST #26.
Setup is 94z 4.8/th400/10bolt spohn tunnel tq arm/spohn solid motor mounts/spohn th400/t56 trans mount/ strange built driveshaft and midwest 10" converter.
Before I put the 9" and turbo setup in i wanted to make sure i got rid of the gremlins. In all the fbodies i have owned im stumped w this one. I have the pinion set at -2 in attached pic with two different angle gauges confirming it. Im getting a lot of clunking making me feel like the tq arm is loose somewhere but have not been able to isolate yet. At about 45mph i get a massive car shaking vibration that sounds like the car wants to throw the driveshaft through the floor.
Any thoughts on what else i can check? I have new tires coming in this week sobit i doubt this is tire derived, but i could be wrong.
It needs to be a -2 difference in relation to the angle of the engine/drivetrain. Your angle currently could be completely off right now even though the pinion is sitting at -2 like your gauge shows. If that makes sense.
Ex: If your drivetrain is at 0 your pinion is at -2 then you would be good. -2-0= -2. You need to measure the drivetrain to actually see what your pinion should be set at.
Pinion minus drivetrain angle.
Hopefully my math is correct. Haha
I'm going to swap the springs too and put back in my SLP SS springs vs this Eibach lowering springs as well this weekend.
Is there enough engagement between the slip yoke and the tailshaft of the transmission?
A friend had a nasty vibration and turns out his driveshaft was about 2" too short.
Something to check anyway.
I had a hard time with pinion angle and ended up at one point having wayyyy too much angle from not doing the math right.
Moderator
Received 1,852 Likes
Make the two angles match. That's the best starting point. Sometimes it makes sense to run a slight negative pinion angle - I run -4 degrees on the trans yoke cap and -3.5 degrees on the rear diff yoke cap for best all around results. This scenario is a "-0.5" pinion angle. YMMV. For heavy track use some guys run -1.5 to -2.
Moderator
One more thing - if you start with the angles matching, pay attention to when it vibrates. If it vibrates under acceleration, you probably need a more negative pinion angle. If it vibrates more under deceleration in gear, then you probably need your pinion angle less negative or maybe even slightly positive.
Moderator
I check it at ride height with the weight on the tires. Usually I'll use four tire ramps to set the car on so I can get my fat *** under the car to measure.
I jack the rear up, and slide under the back. It doesn't upset the suspension. You want it loaded, at least the rear. Just remember when you tilt the car it will change the trans angle but that doesn't matter, you are comparing them to each other. If you tilt the car 10 degrees, then the trans will be at 10, and if you match the angle on the rear you are at zero. Both at 10 equals zero pinion angle. It's not about the pitch of the car, it's the comparison of the two angles to each other.
good tip so i don't have to remove the driveshaft. however at this point I think i have to. I'm going to remove it though so I can measure the slip as well, I hope my driveshaft is not too short at this point. I measured it exactly how Strange said to measure it. I took the drawing with my measurements in the office (they are close to me) and handed it to the tech when they built this driveshaft. Will have to see how things come together this weekend.
I just went through all of this with a new S60 install. I checked the balancer to get drivetrain angle and compared that to pinion angle to get them to zero out, shook like crazy. I took the driveshaft out and measured the tailshaft angle and it was close to the balancer but I made the adjustment to zero the pinion and tailshaft and it shook like crazy. It's like everything else. In theory and in lab conditions, a pinion angle that zeros out the drivetrain angle is the optimum. It just doesn't always work that way when you leave the lab. My driveshaft is lower at the tranny than it is at the pinion. It runs uphill to the rear of the car. It shouldn't matter in theory, but there is some factor in the mechanics of my car that doesn't jibe with the zero angle theory or the -2 result compared to the drivetrain. In the end, I measured the driveshaft angle and put the pinion at -2.5* compared to the driveshaft and it got a whole lot better. It still isn't where I want it, but it's getting there. I may end up at -4 to the driveshaft. If that's where it wants to be, so be it.
Now, I don't claim to be and expert, and I didn't even stay in a Holiday in Express last night, but I have read everything I could find regarding the theory of setting pinion angle and my engineering background and my experience with theory and practical application made me go with a starting point and method that isn't consistent with theory, but worked in my application.
The bottom line is that you have to do what works - for your setup, no matter how wrong it may be relative to a theoretical ideal. That's why the car manufacturers have mules that they drive in actual road and weather conditions and make adjustments that vary from theoretical absolutes but work in the real world.
you guys should stop calling it pinion angle.
a better and more accurate term is phase angle between the front and rear u joints. ideally you want this phase angle to be 0.000° all the time under all operating conditions. the more it deviates from zero = more vibration.
i can somewhat understand on the oem torque arm rubber bushing flexing, and seeing 1/2 to 1° of rotation of the axle under constant heavy load such as w.o.t. down 1/4 mile so then set a phase angle to -1° (axle pointing down) to compensate so there's no vibe at 100mph. What i don't understand is using an aftermarket torque arm with a 3/8" steel mounting plate and poly bushing that doesn't flex then you guys go setting phase angle to -2° or more.... first i don't see the logic expecting a new beefier torque expected to flex that much. and on normal highway driving at constant 70mph takes around 30 hp give or take, point being there's little load on the torque arm, and setting phase angle more than 1° away from zero is bad. never drive your car on the street, only at the track under wide open throttle, but wait then you have to stop so from 100mph on decel you then have a -2° phase angle and wicked vibe. Maybe we should use a torque arm that keeps phase angle at what it was set to with less than 0.5° of change?
and what farmington said is regarding u joint operating angle, the angle between the two pieces the u joint connects (drive shaft and yoke). And it is somewhat important, more so on things like lifted trucks not so much these cars. You also want minimum operating angle but not 0.000° because then the roller bearings in the u joint won't move and lubricate themselves. but the higher the operating angle of the u joints, then the more accurate you need to get phase angle to zero for no vibes. Or higher operating angles are less tolerant of phase angle not being 0.000°.
