Moser 12 bolt whine - in shop.......
I had a cover leak so car was going to the shop regardless
shop indicated the gears were 3.73's and were worn
The whine was more apparent up to 50mph were it then settled alittle but still there...
They fixed 2 leaks, cover and front, and put in a new set of gears and apparently test drove
They said so far the whine is gone down but still trying to see what else is possibly amplifying the sound.... they did mention some bar was close and moved it away
I have read alot of articles that moser has a whine, some because nature of the beast or poor installs or whatever...
Realistically should i be excepting any whine?
car is no way close to stock
Depends on gears and torque arm. A body mount torque arm will amplify the sound. Some brands of gears are just a little noisy....some tend to be more quiet.
shop still has car after 2 days.... they appear to be scratching their heads at this point... new gears helped some of the whine
car has a UMI relocation and torque arm setup....
LS1Tech Sponsor
A little whine is quite common and in many cases cannot be cured. Aftermarket gears are usually a little noisier (and stronger) than oem gears, and produce some of the noise, and in some cases noise will decrease as the gears break in. I recommend 500 miles without going wide open throttle to break in a set of gears to make them as quiet as possible. For many of us, that is extremely hard to do... Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
so i have the car since yesterday.... whine appears to only show up between 40-45 now... in the break in period so keeping it easy here
they mentioned that the exhaust pipe appears to be sitting on the rear end once you have 2 people in the car and that might not help the noise so will have to have an exhaust shop take a look, might need a bracket....
they also mentioned that switching to a BMR arm might help, thoughts ?
LS1Tech Sponsor
Anything that touches the rear can amplify the sound through the torque arm right up to the passenger compartment.
What torque arm do you have on there now? The factory torque arm is made out of stamped sheetmetal and is prone to bending slightly ahead of the rear end. The factory torque arm attaches to the transmission which is hard on transmission mounts but I doubt the rubber that is used in the way it is mounted will transmit much noise. Bob
__________________
LS1Tech Sponsor
I agree. It's the better way to mount a torque arm, but it does amplify and transmit noise. Bob
__________________
LS1Tech Sponsor
Both brands do a very good job of removing the forces the transmission mounted torque arms place on the transmission. The only way I can see that one brand could isolate the noise better would be if it had spongy rubber mounts, which isn't what you want in a performance torque arm. Bob
__________________
i am still working on the 500 miles on the new set... whines starting at 40-50 range but seem to drop off some after.... does seem letting off the gas you an feel the whine through the emergency brake handle.... so annoying....
yeah mine is the same way the torque arm amplifies all the noise
LS1Tech Sponsor
The factory 10 bolt that came in these cars has a very small 7.5" gear. A variation of this rear was used back in the '70's in the Chevy Monza, then in the Chevy S-10. GM had to of known they would have warranty claims when they decided to use this rear in the 3rd and 4th gen f body's, apparently the cost of creating a stronger rear was higher than what they thought the warranty cost would be. This has been a real plus for the aftermarket, as a bone stock LS1 F Body with a manual transmission can break one of these 10 bolt rears! Many people have tried to beef these 10 bolt rears, spending a lot of money in the process. What they normally end up with is a rear that still breaks, as everything on these rears is too small.
The 12 bolt rears that are available for these cars is a step in the right direction. The 12 bolts are well known for being a stout rear that was a factory option back in the day in many performance cars. You can have a 12 bolt in an early Chevelle, Nova, Camaro, etc, and beat the snot out of it and not hurt anything. Put a 12 bolt into a late model f body that uses a torque arm, make a couple 4000 to 5000 rpm launches at the dragstrip, and I can just about guarantee you'll have a lot more gear noise on the way home. The torque arm seems to distort the housing on the 12 bolts, and it seems to happen to all the brands of 12 bolt rears. This does not happen to the 9 inch rears, and there is no price difference between the 12 bolt and nine inch rears. As the horsepower in our engines keep escalating, most people these days go straight to the nine inch rear. The 9-inch has an internal rear-pinion support that also supports the gear end of the pinion to limit gear deflection under high torque loads. This seems to be the major reason why the 9 inch doesn't start whining after high rpm clutch dumps, when the 12 bolt will pick up noise. The 9-inch locates its pinion gear lower on the ring gear to improve tooth contact, better the 12 bolt does. The 9-inch also has a 0.125-inch larger ring-gear diameter and internal pinion support than the 12 bolt. Bob
__________________
After 15 years and 228k miles, I'm still rockin' my original 10-bolt. Despite the car putting down 460rwhp. The tires have been the only thing that's kept the rear alive. lol
But, I'm about to pull the trigger on a 9".
I know what you mean lol.17 years for me but with 90k and about 600 rwhp through a M6 and 4.10 gear. DTS is like an hour from me, and i'd love to get one of their 12 bolts, but after reading stuff like this I may do their S60 instead
