Vibration from rear of car under acceleration above 50mph
So I bought a 2010 SS camaro a few days ago and I notice I have a pretty bad vibration from the rear of the car when I accelerate at 50+ mph. I can throw it in neutral at anytime and rev it from 70-100mph and never get the vibration. It's only when the car is in gear and under acceleration. It does not do it with the cruise set at any speed only acceleration.
So this leads me to believe it can't be engine related, wheel related, or exhaust related. It must be something in the driveline I jacked the car up and can't see anything wrong. It appears all the bolts are tight and can't see that anything is bent.
So my guess is the driveshaft is bent or out of balance or one of the axles is bent? Anybody have this problem? Let me know what you think!
Moderator
Received 1,835 Likes
That's kind of classic pinion angle. But I'm not familiar enough with a 5gen to know if the pinion angles can get as wonky as fourth gen. Check trans rear mount. If its toast, it could be screwing with your trans angle, causes exactly what you're getting
