Ford 8.8" converting to 5 bolt w/4.75 pattern?
I picked up a 8.8" today out of a 89 foxbody. It has a 4 lug bolt pattern and I am wondering if there are any axle manufactures out there that make a 5 lug pattern with the GM 4.75" bolt pattern??
Just pick up a set of 8.8 axles out of a 5 lug car. Then drill the new holes in the flange centered between the old ones... The Explorer 8.8 axles are 5x4.5 iirc. The Lincolns, and big body ford cars use them too.
You need to fill out the order form to get what you need. http://www.moserengineering.com/mose...uction-sheets/
