Moser 12 bolt woes, anyone had this?
Installing the new 12 bolt in my sons 01 Camaro. Did everything it said. The bearing won't sit flush and backing plate won't either due to the bearing. It feels like the press ring is hitting the inside of the housing.
Of course this all happens after 5pm and Moser is closed. So I have to find time to call tomorrow or if anyone here has an answer, would be great.
LS1Tech Sponsor
Have you tried tapping the axles in with a rubber mallet? Sometimes a little persuasion is needed. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
I don't think I have a list showing the 12 bolt axle lengths for the 4th gen F Body. I'd measure the axles and give Moser a call in the morning. Bob
__________________
Looks like 9in axle ends. Had the same issue on my used S60 with 9in axle ends ( was replacing axle bearings is the reason I ran into this issue). The Inner seal was too small for the new wedding ring install on the axle shaft . I removed the inner seal and the axle slid right end.
I left the inner seal out. Not saying it is right, but about an 1,000 miles now. No leaks on the outer seal yet
A guy on yellow bullet installed one today, he told me to measure housing end and bearing. Sure enough, the bearing is thicker than housing end. Bearing is bottoming out in housing.
Moser better figure something out quick. LSFest in a few weeks and my son is coming home on leave before he deploys, to take his car. I'll be pissed if this holds it back.
LS1Tech Sponsor
__________________
LS1Tech Sponsor
__________________
Yep, my strange bearings are the same way, the seal is NOT flush with the housing end. There is a groove in the backing plate that allows for the seal to protrude some.
For the original post that amount you see is perfectly fine, it will expand into the housing end once you install it. Please make sure you go crisscross when tightening the bolts.
Yes I got a call early this morning from Moser and they were right on top of it, Had the original invoice pulled up and all. He said it was normal and the bracket will pull itself into the bearing and press itself into place. That info isn't in the instructions. But he sent detailed pics of the install.
Thanks for the support fellas.
A stock backing plate does not have a groove in it only aftermarket brakes like Strange has a backing plate with a groove in it and the bearing will stick out further than shown when using Strange Brakes.
OP heres some pics of mine if you wanna compare
https://ls1tech.com/forums/multimedi...l#post18965536
It depends on what brakes, bearings, and housing ends you have to make each application work. There is a solution for each one but with so many companies that use different housing ends and multiple different brake options to complete the task can be different every time.
Nah, you misunderstood. Strange 12 bolt (same ends as above), stock brakes (no groove), then switch to strange brakes (grooved) with nothing else changed. How are the bearings loaded the same with two different style backing plates.
Edit: I get it, the bearing depth is located by the axle itself, not the backing plate. The backing plate only locates the seal. I did notice some seepage last week when i pulled them out (they have 200 miles on them). That may be a result of that seal with that backing plate. It wasnt enough to worry about.
The short of it spacers have to be added or removed to achieve the swap from factory brakes to stock but due to the manufactures housing end differences and type of bearing being used will determine the proper install. You can not take a housing end designed for stock brakes and simply bolt on a Strange type backing plate with a groove on it as there is either a spacer to be added or removed dependent again on the manufactures housing end and type of bearing will determine what steps you take.
From Strange about the rear drag brakes:
If you bought a Moser or Strange rear and had it set up to mount stock disc brakes, then you are set up to install this brake package.
You can not add a Strange Brake package to a rear end that was originally set up for stock brakes without adding or removing spacers based on the housing end manufacture. I am not sure if you called to ask someone at Strange the question and maybe got the incorrect answer or they didn't understand what you asked. As yes a Strange brake kit can be added to any housing and any housing end style but based on the housing end and bearing there is other steps that need to happen as it is not a direct unbolt stock and put on Strange.
I have however assembled well over 200 F-Body specific MWC fabricated nine inches while working here and assembled Strange S60, Moser, 8.8, or any other type of rear end housings for customers that have been brought in to be narrowed or for whatever reason. I am the soul person that assembles all housings that go out the door.
If you look at our brake kit listing on our website it even describes this.
https://midwestchassis.com/products/...rear-brake-kit
Calm your ****. That's right, they did come with those spacers. Ok so you use the spacer for stock backing plate, and the strange backing plate has the groove (spacer removed). So they are equal in application.
OP, there are pics of the end spacers in the below thread, which i notice arent in your pic, but i believe our housing ends are the same.
https://ls1tech.com/forums/gears-axl...t-install.html
