Rear Differential Gasket Choices
I have a 2001 Z28 with ~40,500 miles and a stock 10-bolt. To the best of my knowledge I am going to assume that my rear differential oil was never changed by the previous owner. I know that when you change the rear diff oil, you need a gasket. However which kind of gasket is better: RTV silicon or a Fel Pro gasket? Or does it even matter??
PS: I have never changed my rear diff fluid before; this will be my first time. I just want to have everything ready for when I do change it
lube locker gasket all the way. A little pricey, but 100% worth it. Yes it is re-usable and never had one leak. no issues with sticking gasket pieces or silicone to scrape off.
I'm going to have to eat my words on that one. I have one for my 9", and have used them in dana axles, just assumed they made a 10 -bolt version, but they only make an 8.5" version according to their website.
I mean I guess I could use both just to be safe...
By the way, did you guys have any trouble removing the diff cover with the sway bar in the way? I took a quick look underneath today and the sway bar looks like it could get really annoying while changing the gear oil.
I added a drain plug to the housings on my jeep, way less mess.. on my Dana axles I use a sheet of card stock and peen a gasket off the housing, then use Oil rated permatex red silicone. Drain the diffs twice a year if I'm wheeling it, pull the cover about once a year unless it ends up submerged in mud.. almost 300 K on the axles and no issues.
What I don't get is if the entire oil gets drained or just most of it. I bought one of the cheap one from O'reilly since mine was old and had a leak. What are your experiences with them draining the oil?
