My Moser 9 Nightmare!
First off let me say I’m completely and utterly disgusted at the quality of my moser 9” that I have got recently. I have saved my *** off for one these hunks of garbage only to turn out disappointed. My rear came packaged absolutely terrible for the wieght of this housing. Bubble wrap? Seriously? How about some strong plastic to protect the housing ends from impacts? Or maybe even some rubber? When I received my rear I installed the center section as well as the axles. As it came time for back plates to be installed one of the housing ends was damaged! One corner where the backing plates are installed was bent back towards the center section. I had to bend it back myself because I was not going to now unbolt the center section and remove one of the axles to ship this back. Second, after I had the axles and center section installed I proceeded to fill the rear with gear oil. An hour later gear oil is all over my garage floor because the drain plug was leaking. I then had to drain, wrap drain plug with Teflon, and re fill. Still a little leak because whoever welded it in must of been high on meth. Contacted moser, they told me to remove axles and center section and re weld. WHAT? Third, I go to install my brand new afco coil overs and my shocks won’t fit their transverse shock mounts. First off, their mounts are not wide enough for me to slide my shock in, and the mount isn’t deep enough for me to be able to slide the shock back far enough to get he bolt through. Not only that, their transverse shock mount is a terrible design. One spacer was welded in, and the other was left there to allow different width bearings to be installed. Well, my shock doesn’t even fit with the free floating bearing out. I am at my wits end with this garbage.
To the OP, what do you plan to do to correct the shock mount? Looks like you will need to weld new mounting tabs.
Don't lose sleep over it. If there is a problem, find it before you install. I'm sure they would work with you if there are any problems. Check the flanges tho. Mine rear was misaligned to the point that it was ruining tires. I should have known as it was pretty difficult to install the drivers side axle. I had .10° toe on the pass side and .39° toe on the drivers side. I ended up putting the rear on a frame puller to straighten it.
6 Second Club Moderator
Sorry to hear and see your problems with your rear end!! I've had a Moser rear before and didn't have your problems. I hope you get them all resolved. Let us know how this plays out.
Just want to point out, this is quoted from Gabriel shock company:
"Can I mount my shock upside-down?
No. With the exception of a few specialty shocks, you should never mount your shock absorbers upside down. Typical twin-tube shocks are simply not designed to function upside down for many important reasons. Attempts to do this will likely result in poor shock performance, premature failure and potential damage to your vehicle."
https://ls1tech.com/forums/gears-axl...wks-8-8-a.html
