MWC Delivered BIG!
Unfortunately I've been out of town all week, so all I've had time to do since I returned last night was put the car up on stands to get ready for the swap. I'm going to start working on it Friday night or Saturday.
They are awesome! I can't believe how light they are, but you can tell they are capable of handling the weight. I'm much more confident under the car on those than with the cheaper plastic rhino ramps.
either way, i think they make an awesome rear end, well worth the money and know what they are doing. had i known i would have 4 channel issues again, i still would have opted to spend my money with them simply because of their quality and reputation. never do u see people having fitment issues, never do people have tq arm issues, and most importantly, how many failures have you guys seen on here? i just would have not went 4 channel and just had 0 channel abs lol. i wish they weren't a 12 hour drive. i would drive it there and be like "i guess i have a unicorn, because my abs don't work above 80" and see if they could get it to work. if they could offer me some type of guarantee we can get it to work or we don't charge you for the time we spent looking at it then id do it. never would i expect that so i just deal with not having abs i guess.
to the op, i went with the 3.89s as well and i think its the perfect ratio for a 4-600 hp fbody. you won't regret it.
some people get lucky. my only thought was the aftermarket reluctor wheels could be a culprit. figuring maybe their tolerances aren't tight or the fact that they are painted and the stockers are not maybe does something. my advice for anyone attempting 4 channel on a non 10 bolt is to use oe reluctors.
I got the rear in the car yesterday. It was a very smooth process overall, even doing it 100% by myself in my garage without a lift. The only "modification" I had to make was to enlarge the shock mount holes a bit. They were a little too small for the bolt on the Koni SA's I have.
I didn't take great pictures, but snapped a few as it was going in. I'll get a few better ones of the finished product after the driveshaft arrives. The measurement for that was surprisingly short. I was 44 7/8" from the end of the trans case to the face of the yolk on the rear (measurement X on the attached guide from PST). It was actually a stockish 44 1/4" from the tailshaft seal to the face of the yolk. I'm glad I measured!
I still have to install the driveshaft, bleed the brakes, and I'm going to replace the fuel filter and do an oil change while it's up. Looking forward to beginning the break-in process.
yea the tune survived but the idle was ridiculously rich. like really bad but i kinda just let it go. o and half my valve seals were in the pan on my first oil change after he did the cam swap. no big deal
#34
Don't let the wait time throw you off. This rear is ridiculously awesome, and I would have waited another month easily.
#35
thanks for the info. I'm ok with 6-8 weeks, but I saw some horror stories of people being quoted weeks, and then not getting it for 6-8 months. Does paying in full upfront actually make a difference or is that something you just happened to do? Id hate to pay 4k and then wait 6 months, would make it even worse lol.
#36
#37
thanks buddy I appreciate it. Ill give them a call and see what they have to say!
MWC has said that paying in full is the only way to ensure all ordering and production starts right away. If you only give them half up front it may only be enough to account for the labor needed to manufacture the housing. Then more money would be needed before they can order the axles or center section. If you have the ability to pay up front your money is safe with them. Then they can order the center and axles at the same time they begin fabricating the housing. There's definitely an advantage to that. If not, you just want to make sure you ask enough questions to understand how far the deposits will take you before additional funds are required to take the next steps. Communication both ways is needed to ensure a smooth process in an order of this type. They were great on the phone, and in most cases replied to my emails with a few hours.
#38
Just a quick note on my progress and feedback for documentation purposes. I completed the five heat cycles. The first three were perfect; the car rode smooth, there was no gear noise, and no leaks. On the fourth drive I noticed a very slight howl out of the gears on acceleration, and on bumps I could tell metal to metal contact was occurring somewhere. These symptoms continued on the final heat cycle as well. Following the last drive I put it back up and noticed a couple of things; 1) The top torque arm mount has made contact with the frame cross-member above the fuel tank 2) The housing is making contact with the over-axle section of my Corsa catback. 3) my left rear wheel is about a quarter inch further back in the wheel opening than the right. 4) The car was sitting up at least 1/2" higher on the drivers side rear than the passenger side. Here is what I've done with each concern thus far:
1) Nothing. I'm not sure if I'm going to BFH or cut that cross-member. I'm thinking I'll find an alternative solution to it...either moving the rear back further or stiffening up the springs using airbags
2) I made a slight adjustment to the exhaust, but I'm not sure I had enough room to completely fix that problem, so I may need to visit an exhaust shop
3) I took off the left rear LCA and shortened it by a quarter inch. This centered the wheel, which now matches the right side. I used the factory LCA's to set the length to stock on the new ones, so I'm 90% sure they were both identically sized upon install. I could have messed that up, however, but the advantage of the adjustable LCA's is that it doesn't matter if it's the rear, body, or my initial adjustment...it can all be fixed
4) I had a similar problem with the stock rear, as many others have mentioned, but it was more exaggerated now. I think I may have torqued the panhard while the suspension was unloaded, so I loosened it, had my wife wit in the car while the suspension was loaded, and then re-torqed the bar.
I have not driven it since these changes were made, but I will this afternoon. I'll be sure to follow up with my results.
#40
I used the Race Ramps on the front and then put the rear up on jackstands. That allowed me to load and unload the rear suspension as needed to facilitate the swap. Once everything was bolted up, I was able to put the front and back on the race ramps to make it easy to do the rest. They are awesome and totally worth the money.
