Rear gear for turbo and th400, juat swapped from M6 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
Reload this Page >
Notices
Old 07-11-2018, 08:39 PM
necrocannibal's Avatar
Default Rear gear for turbo and th400, juat swapped from M6
Trying to figure out what gear I need now. I am coming from an M6 and it has 3.42s in it and now feels like it's goin to run out of gear before the 1/4 mile is up. I'm on a 26 inch tire and will probably stay there. What gear should I go to give me some more up top without going too much the other way?
necrocannibal is offline
Old 07-11-2018, 09:05 PM
Maybe a better question would be what mph at what rpm will the th400 get me with a 26 inch tire and a 3.42 that I have now? Feels like it will max out around 130 or so.
Old 07-11-2018, 11:07 PM
What rpm you running through the traps? 6000rpm should be about 135, going to a 28" tall tire would get you another 10mph at the same rpm.
http://www.crawlpedia.com/rpm_gear_calculator.htm
biketopia is offline
Old 07-11-2018, 11:10 PM
I haven't run it yet but I'm anticipating this car trapping mid to upper 140s and don't want to spin it 7000 rpms but also don't want it to be lazy out of the hole. It will mostly be a street car though.
Old 07-11-2018, 11:12 PM
That calculator you posted said I would be at 6630 rpms at 150 mph so that isn't too bad if it's correct.
Old 07-12-2018, 07:27 AM
Should be pretty right. I tired a few just to self check as it's been awhile since I was playing around with gear ratios and such. What size converter you running to help it get up in the power band?
Old 07-12-2018, 07:50 AM
It's a 10 inch converter but I don't know all of the details about it, I'm waiting on Dalton to email me back with the specifics of what he speced out for me.
Old 07-12-2018, 07:52 PM
Well I decided to go to a 28 inch tire and keep my 3.42s and see how it goes. With a 28 inch tire it looks like I will be turning 6150 rpms at 150 mph so that is tolerable for now. If I needs a little more rpm for highways pulls I'll switch to 3.08s but and hope it doesn't kill my launch.
Old 07-13-2018, 06:44 AM
I would think you'd be ok with what you have. Hopefully your converter is set up right to jump you into building boost pretty easily.
Old 07-13-2018, 10:10 PM
Hopefully so, I'll know for sure next week when the rims and tires get here.
Old 07-22-2018, 05:16 PM
What is the engine and turbo size? Your launch shouldn't be a problem at all.
rpturbo is offline
Old 07-22-2018, 05:20 PM
It's a 408 with a Borg S480, 96 mm turbine, 1.25 AR.
Quick Reply: Rear gear for turbo and th400, juat swapped from M6
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
