9" axle shafts for 31 spline true trac
Old 08-22-2018, 12:51 PM
dyermullet's Avatar
Default 9" axle shafts for 31 spline true trac
I have new moser 9" 31 spline axle shafts, and a new 31 spline truetrac. Their is an excessive amount of play in the axle splines to the truetrac. Moser has been no help at all with this, they said it is normal, it is not normal.
What manufacture 9" axle should I buy to work with my truetrac? I have read all the threads on here and yellowbullet about the different manfacture spline dimension and the recommendations of matching your spool and axle shaft from the same company. Who's axle spine best matches up with the truetrac?
Thank you
Old 09-22-2018, 02:02 AM
Macs4kids's Avatar
I have moser 31 spline axles and their trutrac and all my clearances were tight! Not sure you have a vendor specific problem or just a flaw in the making of one of the 2 pieces.
