What is a "mini-spool"?
Old Jul 31, 2004 | 03:50 AM
89FormulaLS2's Avatar
Default What is a "mini-spool"?
I bought a used Moser 9" recently to put on my Formula. How does a mini-spool work and how is it different from a Spool or a Posi?
Old Jul 31, 2004 | 12:44 PM
MyLS1Hauls's Avatar
A mini-spool just replaces the "guts" of a standard diff. It works like a spool, just not as strong.
Old Aug 3, 2004 | 02:43 PM
F1_SS's Avatar
then whats the point of it? just cheaper?
Old Aug 3, 2004 | 03:28 PM
MyLS1Hauls's Avatar
Yup...and easier...you dont have to remove the carrier from the housing...
Old Aug 6, 2004 | 01:45 PM
Colonel's Avatar
Weak. Don't do it.
Old Aug 9, 2004 | 03:43 PM
BigPlanTransAm's Avatar
i called summit to see if they made one for my 02WS6 to minimize downtime until i get a 12-bolt. they said no one makes them...
is this true? does anyone know of someone who does make them?
i just want to be able to drive/race the car untill i find a good deal on a 12-bolt
Old Aug 10, 2004 | 10:11 AM
MyLS1Hauls's Avatar
A mini-spool wont really help prolong the life of the stock 10 bolt. There are too many other weak links. I'm not even sure if anyone does make a mini for a 7 5/8" 10bolt. You'll need to run c-clip eliminators anyway.
Old Aug 22, 2004 | 03:08 PM
Sunsceamer's Avatar
Cheap Redneck Spool
Remove rear end cover. Clean out oil use lots of brake clean. Take welder and weld the spiders together. DO NOT weld axles to spiders.
Old Aug 26, 2004 | 07:41 AM
2MuchRiceMakesMeSick's Avatar
The only reason you would run a true spool is for strenght. The mini spool is a weaker spool, why anyone would run it? Im not sure? No one I know runs one.
Old Aug 30, 2004 | 09:36 PM
Steve in Seattle's Avatar
Some circle track guys run them for class limitations where a standard spool is not permitted.
Stronger than a posi I guess, but for a street application you may want to look at a Detroit locker, or the new posi-locker from Auburn (I think they call it the ECTED or something, basically an electronic locker that is a 2.5:1 bias posi when unlocked).
To my knowledge no one makes a 7.5" mini-spool... I've seen a few people search for one over the past 5 years or so. For that matter, I belive a full-sized spool is fairly rare as well (although I swear I read about a company in the south that made them for cheap). Sticky tires + full spool + high torque = broken splines. They're not popular for a reason.
Old Sep 1, 2004 | 10:44 PM
SeeYaSucker's Avatar
Richmond gear makes them, but don't get one, theres no reason to
