how much for new AXLE??
Old 02-09-2005, 04:11 PM
Uno99's Avatar
Default how much for new AXLE??
I got my 3.73's installed to day and my mechanic said my axles are looking bad. He did not give and idea on what the cost. I would like to know how much I'm looking at. Should I be worried about snapping the axles I went from 2.73 to 3.73. My car only makes 311rwhp.
Old 02-09-2005, 05:18 PM
14 Second Truck Club
mzoomora's Avatar
Call superior gear or drivetrain direct in california. I dont have a number off hand, but they make a upgraded axle for a reasonable cost.
Old 02-09-2005, 06:10 PM
Uno99's Avatar
Just talked to mechanic I guess wear the axle bearing was on the axlxe shaft it is pitted. He said he relocated the axle bearing. Even if it is pitted I dont' make near enough HP to have to worriy about it.
Old 02-09-2005, 06:53 PM
mzoomora's Avatar
Relocating the axle bearing (axle saver bearings) isnt a good idea on a car that sees long highway trips. They are a sealed unit, so htey dont share oil with the rest of the housing, which can cause them to overheat. If it doesnt see a lot of long highway miles it will be fine. Just letting you know.
Old 02-09-2005, 06:59 PM
Uno99's Avatar
I appreciate the info sounds like I sould just replace the axle shaft when I change the fluid after break in period.
Old 02-10-2005, 07:19 PM
TRex's Avatar
I've got a couple of spares if you decide to go back to stock, $30 ?
