LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   Sometimes it sometimes it won't (https://ls1tech.com/forums/gears-axles/2821-sometimes-sometimes-wont.html)
mcflyz28 Nov 19, 2001 07:32 PM
Usually when I'm coming up to a light I just push the shift knob to neutral and most of the time no problems, but seems like at times the tranny is reluctant to come out of gear, anybody have a clue, the problem occurs mostly in 2nd or third where I actually have to use the clutch, could it be too many powershifts ?
c4c5specialist Nov 20, 2001 05:10 AM
Re: Sometimes it sometimes it won't
Hi there,
It could be the powershifting, remember that syncronizers take the brunt of powershifting. This would wear them at a higher rate. The reason that it may increase effort, is that they syncro also helps keep the gear in, but if metallic pieces get stuck inside the hub, you may experience the condition.
This is speculation, and I would have it checked.
Besttoyou, c4c5
mcflyz28 Nov 20, 2001 01:35 PM
I'm starting to make my list of things to get checked out by February ( end of warranty ). I'll add the synchros.
© 2026 MH Sub I, LLC dba Internet Brands
