"Breaking Rear End"
as long as you stay you stay with 3.42's or > the only weak link is the differntials. ive gone through a torsen, an alburn pro and an eaton.
never felt like droping such a large amount of $ on a 12 bolt.
Why you got problems again???
I managed 1.43 60fts and multiple 1.45-1.48 60fts by building it right. Every component has a breaking point hands down. I pushed the breaking point to a level that even surprised me. It's still extremely solid and quiet as a mouse.
I installed an Eaton H/D posi unit (clutch pack type that is rebuildable). I welded the axle tubes. I kept the indestructable 3.23 GM gears, added an aluminum TA stud and girdle kit for support and had a solid pinion spacer to eliminate internal pinion movement. I also added LCA relaoction brackets to eliminate wheel hop. I spent about $1100.00 on it, but I didn't have the funds for a 12 bolt at the time. It never broke. 1BadZ pulled 1.3 60 fts with an identical unit lauching on the gas out of the hole. I stayed NA and drove to and from the track.
I did recently install a Mosier 12 bolt so the 10 bolt is up for sale. I have added a bit more HP and didn't wnat to test the maximum limits of the 10 bolt ($600.00)
The 10 bolts are lighter and faster if your HP is with in it's boundaries. The 12 bolt absorbs about 15 RWHP. I should have tested the 10 bolts boundaries.LOL.
