Should I replace the stock Steel Driveshaft ?
I'll soon be adding the MMS Stage 2 heads and I'm concerned about the steel driveshaft. Will it hold up with the added HP & tq? Should I go with a Mark Williams aluminum, chromoly or stick with the steel and just get a driveshaft safety loop?
I just want it to be safe.
Thanks,
Jerry <img src="images/icons/rolleyes.gif" border="0">
[ November 25, 2001: Message edited by: Palm Beach Z ]</p>
Thanks,
Re: Should I replace the stock Steel Driveshaft ?
Power wise you will probably be allright - what might worry me is driveshaft RPM. If you do any kind of high speed runs (140+), or if you switch to 3.73+ gears then I personally would rather have the better balanced driveshaft.
Either way it will not be a waste to get the better driveshaft, and I would - just for safety sake.
Chris
Chris
You know worse comes to worse Jerry, you could take your DR to Driveshafts Unlimited in Ft. Lauderdale and get it balanced and have heavy duty u-joints thrown in for around $100.
[ November 25, 2001: Message edited by: YOOFORMULA ]</p>
Chris, I already have the 3.73's. For finance reasons, I'm going to get the BMR driveshaft safety loop for now. And later when things are a little more stable, get the Mark Williams Cromoly shaft.
Thanks for your responce.
Jerry <img src="images/icons/smile.gif" border="0">
