LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Gears & Axles (https://ls1tech.com/forums/gears-axles-15/)
-   -   3.73's with 10 bolt??? (https://ls1tech.com/forums/gears-axles/288163-3-73s-10-bolt.html)
TN94Z Mar 10, 2005 04:12 PM
How much if a waste is it to install a set of 3.73's in the stock 10 bolt? I have heard that you would be better off just saving the money until you can get a 12 bolt...is this pretty accurate?
TheBlurLS1 Mar 10, 2005 08:45 PM
this is accurate if you are running a 6-speed cars (not so bad for 3.73's but 4.10's like to blow alot more often).
3.73's in a 10 bolt behind an auto trans isnt bad at all. when you start making big power, you will need to upgrade.
ULTIMATEORANGESS Mar 10, 2005 09:06 PM
i went with 3.73s.
im hoping it last awhile.
on rear #3 :cry:
© 2026 MH Sub I, LLC dba Internet Brands
