Rear End Making Clunking Sound?...
It only happens when I floor it and when it finally hooks up; I hear one loud CLUNK from the rear of the vehicle. It has about 54k on the odometer, if that helps. Any thoughts on what it might be? TIA
Re: Rear End Making Clunking Sound?...
Do you have the Torsen unit? You may have excessive play in the rear due to the wearing of the differential. Take your car to a reputable rear end shop and have them take a look. Might be time for a new OEM take out posi unit from SLP. They're a great buy at only $99!
-Kris
-Kris
Check your tranny mount, It is very hard to tell unless you jack the car up high enough for you to get up under and then put a jack under the tranny and jack it up and see if your mount seperates. <img src="images/icons/wink.gif" border="0">
Mine does the same thing. I believe mine is the lca's. Only have 11k on the car and its done it since i have owned it. Piece of crap stock suspension parts.
