Can someone explain to me.....
Someone else can fill in on all the details
There are a few different things that can go wrong in a 10-bolt. 99.5% of the time, when someone is running 4.10's they typically strip the teeth off of the ring gear and/or pinion gear. The higher you go numerically the smaller the teeth get. You obtain a gear ratio by counting the # of teeth on the ring gear and dividing it by the # of teeth on the pinion gear. I've also seen twisted axles. The stock units are crap, and a lot of power can twist them easily. Right after my friend's 422 cid was built, he still had the 10-bolt w/ 3.73's. On the 2nd pass with ET Streets, he twisted the left axle in 1/2. You can also have the posi problems mentioned above.
Don't think that you're home-free when you get a 12-bolt or 9". They can have their problems, too, but they'll take a LOT more abuse compared to a 12-bolt. I had a Strange 12-bolt in my '98 T/A, and my HD 33-spline Eaton posi broke after 3,500 miles. The spider gears shattered on a launch. I had changed gears just prior to this, and a lot of metal shavings were found floating around. I call Eaton up, and they told me that it only has a 6-month warranty. He also said that even if I was within the warranty period that they wouldn't cover it because I was running slicks. <img src="images/icons/rolleyes.gif" border="0">
