Suspension bushings when using 1LE rear sway bar?
Texas Director
I am going to replace my factory rear sway bar with a 1LE rear sway bar, which is a larger diameter. Do you also have to replace the factory bushings that wrap around the sway bar and mount to the axle when going to the 1LE bar?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, you do need to replace them. Might as well get the Energy Suspension polyurethane bushings to further stiffen them up. I bought new GM end links because they're poly anyway and fit perfect.
