For those who have a TRUTRAC
I have been trying to find a Trutrac for my MOSER 12 bolt w/33spline axles and 4.30 gears. 4 series carrier
Problem is, that unit has not been released yet. Moser is the first slotted to receive them and thats not going to happen for another couple weeks, if at all?
Kip at moser said the only other option is to get a 3 series unit and run a thick ring gear.
Is this safe for drag race applications?
My EATON HD800 busted and my car has been on jackstands for almost a month now and I need to get it back and driveable again.
Thanks,
Jeff
Thanks,
Jeff
Originally Posted by TRex
I don't know why it wouldn't be safe ? A thick ring gear should be stronger than a thin one ?
Now I'm having a hell of a time finding the thick gear setup. Moser appears to be the only ones who have one. From what I was told, there are only two manufacturers of the thick gear setup, US GEAR and RICHMOND. US GEAR is supposedly on national backorder, and RICHMOND's are hard to find.
Moser has the Richmond, and they said it would be very noisy because it has alot of nickel in it.
Jeff
The Richmond gears do indeed tend to be noisier than the gears made by US Gear, but you don't have too many choices. You could go with a spool, which is what I am going to do. Bob
I got the same story on the 33 spline, 4 series True Trac last October when I was looking for a replacement to my Eaton HD posi. You should be fine with the 3 series carrier and a thick gear, however, I've never seen a 'thick' 4.30 gear. The 4 series 4.30's were on backorder in Oct. '04 also. Richmond and Motive gear both make them. US Gear re-boxes the Richmonds. Last I spoke to Motive, the 4.30's were discontinued. Are you sure the 33 spline True Trac is even available? All I've seen is the 30 spline, 3 series thus far for the 12 bolts. Also, how well the True Trac will hold up to drag strip launches still remains to be seen. I was nervous about that. Ultimately I sold my 12 bolt because I couldn't find a suitable replacement (other than a spool).
You can always go to Tom's Differentials and have them build you an Eaton with their 4340 heat treated / cryo'd spiders. Thats about $800. Or go to a spool.
Good luck!
Good luck!
Us gear 430 are 10-43 on the tooth count,richmonds have a 9 tooth pionion and are 433 ratio.They are not reboxed richmonds!!!Get your **** straight.The 4 series trutrac
has been promised for a year now,I am still waiting also.
Happy you guys brought this subject up, I am going to rebuild my
12-bolt/4.10/33-spline/eaton/ rearend soon and wanted to get the True-Trac and also wanted to get some quieter gears, Moser setup my rearend and it howls like a coyote, can't stand it anymore, car sounds like **** inside, been waiting for the True-Trac to come out for awhile now for our rearends!!!!
