Repairing limited slip?
I have an 00 car, in which I assume the limited slip is gone. There is only rubber on one side of the car after the track, only the right tire is worn down from racing, and in the air, turning the driveshaft only turns one tire. So correct me if I'm wrong but is this limited slip shot? Still drives great on 1.9 60's.
Provided it is gone... is there some kind of rebuild kit for it, or should I just trash it and get a new one? SLP sells a kit with gears, posi & install kit for around $600, which seems fair...
Yah sounds to me like your clutches in the diff are wornout. I have the exact same problem. what is the part number on that SLP package you mentioned that sounds like a good deal. Oh on the rebuild I'm not positve but I think our stock diffs are the auburn cone clutch style and aren't rebuildable
