rev limit on 3.73's... My rev limits before the trans can change to the next gear.Do I need a shift kit or can the Predator do the job just by increasing shift firmness or shift points?Works fine with the 3.23. |
You probably just need to correct the MPH shiftpoints, this is what's lagging RPM when you change gear ratio upward. The Predator gives you this access. Get out your calculator, figure up the new MPH by scaling old ones by (3.23/3.72) or 0.86x and see how that does. |
| All times are GMT -5. The time now is 12:47 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
